Contributor I
Mobility Master Management Login with RADIUS
Hello
which VSA must i use to give an administrative user node level permissions on a Mobility Master?
For a role i can use Aruba-Admin-Role VSA with value of predefined user roles.
Steffen
Regular Contributor II
Re: Mobility Master Management Login with RADIUS
Hi steffen
I expect the same as radius login on a ArubaOS controller running version 6.x
Search for that
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Contributor I
Hey Frank,
for the roles, yes, that’s the same.
But Mobility Master has a Managed Device hierarchy and for that I search the radius vsa to allow users only write access to a defined path.
For example, I have two node hierarchy
/md/office/controller1 and
/md/production/controller2
and i would like to authenticate an user to the mobility master with radius to only write access to the node hierarchy with controller2
Steffen
Contributor I
Aruba-Admin-Path
thanks for sharing.
Cheers, Frank
