Super Contributor I
Mode-AP and Contaiment
Hi Team,
It may be ap mode and perform both contained?
Re: Mode-AP and Contaiment
I'm not sure I'm understanding your post. Can you elaborate a bit please?
James
Cheers
James
Super Contributor I
Ok, Sorry.
My RF Management, 802.11a/g radio is configured mode: AP-MODE. Is possible manually contained in this mode?
Ah ok, think I got you now. :)
This should help:
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/AP-mode-and-AM-mode/td-p/96303
Cheers
James
Cheers
James
