this thread is a little bit older, but I wanted to point out that the Rel. 6.2 User Guide states:
Number of WLAN SSIDs Supported
By default, you can create up to six networks or WLANs. You can enable the Extended SSID
option and create up to 16 WLANs. OAW-IAP-175, OAW-IAP-104, and OAW-IAP-105 devices
support up to 8 SSIDs and RAP-3WN, OAW-IAP-92, OAW-IAP-93, OAW-IAP-134, and OAWAOS
IAP-135 devices support up to 16 SSIDs. After you enable this option, the number of SSIDs that
become active on each OAW-IAP depends on the OAW-IAP platform.
So IAP105 supports 8 SSIDs all together instead of 8 per radio and IAP93 supports 16 SSIDs.
Is this correct?
