  • 1.  Netservice
    Posted Sep 27, 2016 11:05 AM
    I am a newbie to Aruba.  There are a number of netservices running on our 650 controller that I want to disable.  However, when I type the "no netservice <netservice that is enabled>" I get an error message stating that it is in use.  Is there a default setup that I have not comprehended since I do not have any interfaces configured with any of the netservices?
    Thank you
  • 2.  RE: Netservice
    Posted Sep 27, 2016 11:08 AM
    You cannot remove the defaults. They don't do anything if you don't reference them in your policies.
  • 3.  RE: Netservice
    Posted Sep 27, 2016 11:24 AM
    Hi Tim,
    I have "netservice svc-telnet tcp 23" in my 650 running-configuration.
    I do not see any other reference to this anywhere in the running-configuration..
    When I typed "no netservice svc-telnet tcp 23" and issued the "write" command, I got a message that it was in service.
    How do I disable or shutdown this netservice? Is there a "show" command that also shows default configurations similar to Cisco's "show run all"?  Thank you
  • 4.  RE: Netservice
    Posted Sep 27, 2016 11:25 AM
    Tim,
    I was able to successfully add "netservice svc-ssh tcp 22" to m 650 running-configuration.  It wasn't there before.
  • 5.  RE: Netservice
    Posted Sep 27, 2016 11:29 AM
    You can't remove it. It doesn't do anything, it's just an alias.
  • 6.  RE: Netservice
    Posted Sep 27, 2016 11:42 AM
    Tim,
    So each of the netservice entries in my running-configuration are just alias?  If so, thank you very much for clearing my cobwebs.
    --- John Imperial, IEEE Wireless Communications Professional
  • 7.  RE: Netservice
    Posted Sep 27, 2016 11:44 AM
    Tim,
    If each of the netservice lines are alias, then this is very similar to the Palo Networks firewalls.
