Number of SSID
  • 1.  Number of SSID
    Posted Nov 23, 2017 12:36 PM
    What is the benefit if we reduce number of SSID
    Is it good idea  to keep external antenna in  high ceiling
  • 2.  RE: Number of SSID
    Posted Nov 23, 2017 04:33 PM
    By lowering the number of SSIDs you are broadcasting you can reduce the amount of airtime used up by beacons. This depends on your minimum data rates, the number of SSIDs, and the number of radios on the same channel.
    Revolution wifi blog as a great excel calculator which you can use to find out how much overhead your network configuration will result in.
    http://www.revolutionwifi.net/revolutionwifi/p/ssid-overhead-calculator.html
    As for antenna being high in ceiling, it really depends on the AP and antenna you are using. Its hard to answer without seeing floor plans and knowing more about your environment and infrastructure. Typically keeping AP/Antenna above the users is best as it results in better RF line of sight to the device, but it's not always the best bet.
    _ELiasz
  • 3.  RE: Number of SSID
    Posted Nov 27, 2017 09:14 AM
    How the airtime will be increased if  number of ssid increased ?
    Will it be same if one or two
  • 4.  RE: Number of SSID
    Posted Dec 08, 2017 02:27 PM
    Each SSID on an Access Point is sending beacons. Eash SSID sends a beacon about every 100 ms. If you have 1 SSID on 1 AP, you are sending 10 beacon a second. If there are 2, you are sending 20 beacons. And so on. Each SSID has to send out unique beacons with its own information. More SSIDs = More Beacons being sent = More airtime being used.
