OAW-AP175 console problems
Hi all, I had a configuration problem where the AP175 cannot connect to the aruba-master.
I followed the procedure noted in "http://community.arubanetworks.com/t5/Aruba-Instant/How-do-I-reset-IAP-175-to-factory-settings/td-p/48296
I can get to the apboot> prompt  but then the AP cannot accept/display the factory_reset command or any other command that I have issued at the prompt. I've tried different machines, cables, terminal programs but no joy?
Can anyone help with this problem?
Re: OAW-AP175 console problems
The only thing I can think of is to make sure flow control is not on.  If you get to apboot, it must be accepting some input....
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
That solved the problem cjoseph; Thanks mate.
Awesome mate!
