OS Upgrade process in multi-controller environment with mesh APs
  • 1.  OS Upgrade process in multi-controller environment with mesh APs
    Posted Aug 26, 2014 04:29 PM
    I have a client with a two controller, master-local controller configuration.  They have mesh APs using the Local as primary LMS, and the Master as a backup LMS.  For non-mesh Aruba controller OS upgrades I normally simply push the code, and reload all controllers simultaneously.  For this environment is there a better way?  The client will be upgrading from 6.1.x to 6.3.x.  The Mesh APs are all 175s.
  • 2.  RE: OS Upgrade process in multi-controller environment with mesh APs
    Posted Aug 26, 2014 05:17 PM
    I used to do the upgrade for mesh and non-mesh the same way as you described I never experienced any issues.
  • 3.  RE: OS Upgrade process in multi-controller environment with mesh APs
    Posted Aug 26, 2014 05:19 PM
    Sweet.  Thanks.  Always a bit of fun (worry) when upgrading a large mesh network's controllers.
