Has anyone seen this? What would cause an AP105 to boot up orange on the 11a/n and 11b/g/n. other AP 105's are booting up fine.
Fritz
most likely you have disabled 11n on both the radios.
check the "801.11a radio profile"and "801.11g radio profile" under rf management and see if "High throughput enable (radio)" is enabled.
-Ariya
