Hello Friends,
I have WLAN deployment where Indoor APs (207) came UP with the Controller 7210 while the Oudoor ones (365, 367) couldn't be controlled. All the cabling is good and tested. Those APs got their IP adresses from DHCP but couldn't be Up on the CTRL (the CTRL is Layer 2 connected to all APs)
Is there any specific firmware loading that need to be done for those Outdoor APs? It is strange since I didn't get that problem with the Indoor ones.
Could you please help me with this?
Thanks in advance
Actually, the AP is Layer 2 connected with the CTRL, so no need to get the controller-ip.
For the firmware, my CTRL is running 6.5.1.5 version.
Colin, are you sure that this AP requires 6.5.2 ?
Hey, yep the ArubaOS code is 6.5.2.0.
http://www.arubanetworks.com/assets/ds/DS_AP360Series.pdf
Do you also have the ability to attach a console cable to the AP and verify the behaviour?
@TigerWave wrote: Actually, the AP is Layer 2 connected with the CTRL, so no need to get the controller-ip. For the firmware, my CTRL is running 6.5.1.5 version. Colin, are you sure that this AP requires 6.5.2 ?
Yes.
Thanks a lot.
Could you please share with me the link to download this version.
support.arubanetworks.com
