We are placing a AP175 with D805 antennas on the outside of a building. When provisioning the AP in the controller, there are settings for Antenna Bearing for each radio. Is this setting the degree measurement from North? Is the AP Orientation setting in Airwave the same thing?
There is also a setting for Antenna Tilt-Angle when provisioning the AP. In the case of a D805 mounted against the wall straight up and down, that setting would be 0, right?
Robert
