- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
05-03-2016 12:10 PM
I'm in the process of designing a network that will require bridging some pretty significant distances with wireless. I may need it to be able to reliably bridge anywhere from 1100 to 2000 feet. I read through the Outdoor MIMO VRD and I'm now I'm torn between the idea of using AirMesh Routers or AP 27X (either 277s or 274s with some relatively high-gain directionals).
The network is going to include indoor APs and a 7200 series controller so I'm pushed toward the AP 270s, but I've run into some issues with them in the past and I'm a bit concerend given the distances between the mesh nodes. I know this isn't a ton of information, but assuming that I will be able to achieve line-of-sight between the APs/Bridges what would the recommended solution be?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-03-2016 12:13 PM
2000 feet will not be an issue, look at using a pair of 277 for that PtP link run back to your controller.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
