Contributor I
PEFV
If a customer is trying to terminate VIA VPN sessions to a DMZ controller, do they need the PEFV licence on both the master and the DMZ local, or just the local?
Re: PEFV
I'm not 100% sure but I would bet money on it working with just the PEFV on the local controller.
Cheers
James
Re: PEFV
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: PEFV
If you run master/local, you will need a PEFV license on your master as well as you cannot enter the required VIA configuration on the master without PEFV. For this reason, it may make sense to have separate (all master, or separate master/local) controllers for VIA operation. Please check with your local Aruba Sales team if you need a definitive answer.
