last person joined: 33 minutes ago
PPPoE connenction on Controller 7010 won´t work
  • 1.  PPPoE connenction on Controller 7010 won´t work
    Posted Apr 19, 2016 03:36 AM
    Hi everyone,
    we have an Aruba controller 7010. PPPoE is configured on the controller, but i can´t establish a connection.
    WAN connection is configured on Port Gi0/0/0. This is the complete configuration:
    interface vlan 2
    ip address pppoe
    ip pppoe-username michon2
    ip pppoe-password 8c2ded2e3669bb6263b65facb69635da
    ip nat inside
    uplink wired vlan 2 priority 1
    no uplink wired vlan 1
    no ip default-gateway import dhcp
    no ip default-gateway import cell
    interface gigabitethernet 0/0/0
    description "GE0/0/0"
    trusted
    trusted vlan 1-4094
    ip access-group "allowall" session vlan 2
    switchport access vlan 2
    no spanning-tree
    PPPoE username: michon2
    PPPoE password: <HIDDEN>
    PPPoE service name: <NONE>
    PPPoE VLAN: 2
    PPPoE is enabled. But connection is not established
    Everything okay with the configuration? Any other ideas, what could be the problem?
    Thomas
  • 2.  RE: PPPoE connenction on Controller 7010 won´t work
    MVP GURU
    Posted Apr 19, 2016 01:11 PM
    @thomas.mirowski wrote:
    Hi everyone,
    interface vlan 2
    ip address pppoe
    ip nat inside
    trusted
    trusted vlan 1-4094
    no spanning-tree
    PPPoE VLAN: 2
    Thomas
    Hi Thomas,
    What Process log say ?
  • 3.  RE: PPPoE connenction on Controller 7010 won´t work
    Posted Apr 20, 2016 02:28 AM
    The problem is solved.
    The PPPoE configuration at the concentrator was using CHAP. And this didn´t work with the Aruba controller. After cofiguring PAP at the concentrator i was able to authenticate via PPPoE and i also get an IP from PPPoE.
