Contributor I
Port-channel on Cisco 2960 not working.
Hi there
I have an AP 225 that I’m trying to get ether/port channel working.
For some reason the PWR light on the Access point is Orange/Amber and ETH1 is off.  I tried rebooting it and it does turn on green (power) then goes to Orange. Both Ethernet ports do come on and one goes off. My access point is directly connected to a Cisco 2960 switch with poe+. Can someone help? This is urgent. Thanks
interface GigabitEthernet2/0/14
description "AP273"
switchport access vlan 1709
switchport mode access
mls qos trust dscp
spanning-tree portfast
channel-group 2 mode active
end
CWC-269-1#sh ru int g2/0/15
Building configuration...
Current configuration : 186 bytes
interface GigabitEthernet2/0/15
description "AP273"
mls qos trust dscp
end
Re: Port-channel on Cisco 2960 not working.
You need to have LLDP enabled on our Cisco interface. That is the way the AP negotiates POE+ with the switch..
Contributor I
Hi there
What is the correct commands? I used lldp receive and transmit. Thanks
Blake Crossley
Network Administrator
Information Technology Services
c/oKeyano College
8115 Franklin Avenue
Fort McMurray, Alberta
T9H 2H7
Phone: 780 792 5711
[cid:image001.png@01CED3FF.C0C832F0]
[Description: Description: facebook32x32] [Description: Description: Twitter32x32] [Description: Description: YouTube32x32] [Description: Description: LinkedIn32x32] [Description: Description: Camera32x32]
This communication is intended for the use of the recipient to which it is addressed, and may contain confidential, personal, and/or privileged information. Please contact the author immediately if you are not the intended recipient of this communication, and do not copy, distribute, or take action on it. Any communication received in error, or subsequent reply, should be deleted and destroyed.
? Please consider the environment before printing this email.
Please execute:
show ap debug system status ap-name <name of ap> | begin "Power Status"
That will tell us what power was negotiated...
Also, see the post here:  http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/PoE-problem-IAP-325-on-PoE-ports-are-only-using-15-watts-instead/m-p/290781#M17746 for the command that they used.
Contributor I
Still nothing.
 description "AP273"
 mls qos trust dscp
end
CWC-269-1#sh ru in gi2/0/15
 description "AP273"
 mls qos trust dscp
end
Gi2/0/14              30.0                 30.0
CWC-269-1#sh power inline gi2/0/15
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi2/0/15  auto   off        0.0     n/a                 n/a   30.0
Interface  AdminPowerMax   AdminConsumption
             (Watts)           (Watts)
Gi2/0/15              30.0                 30.0
Contributor I
Still not working.
Contributor I
Gi2/0/14  auto   off        0.0     n/a                 n/a   30.0
CWC-269-1#sh ru int port-channel 2
Current configuration : 84 bytes
interface Port-channel2
end
CWC-269-1#sh ru int gi2/0/15
 description "AP273"
 mls qos trust dscp
end
CWC-269-1#sh ru int gi2/0/14
 description "AP273"
 mls qos trust dscp
end
Contributor I
CWC-269-1#sh etherchannel 2 port
                Ports in the group:
Port: Gi2/0/14
Port state    = Down Not-in-Bndl
Channel group = 2           Mode = Active          Gcchange = -
Port-channel  = null        GC   =   -             Pseudo port-channel = Po2
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi2/0/14  SA      down      32768         0x2       0x0     0x20F       0x45
Age of the port in the current state: 0d:00h:50m:01s
Port: Gi2/0/15
Local information:
Gi2/0/15  SA      down      32768         0x2       0x0     0x210       0x45
Unless I missed it, you didn't show the output of the Aruba command above.  Quite frankly, if it doesnt negotiate high powered POE, it will not bring up the second port and anything you are trying to accomplish with LACP will not work.
