Problem Master-Local Controller
We have problem with master controller and local controller, master and local cannot synchronize. Master Controller Aruba OS Version 3.4.4.3 and Local Controller Aruba OS Version 6.1.1.0.
We ask for the best solution,what should we do.
Re: Problem Master-Local Controller
this eror log master and local controller http://www.mediafire.com/?ge8oto8l2lgmqle
can i downgrade  Aruba OS 6.1.1.0 to Aruba OS 3.4.4.3 ?
They cannot synchronize because they are different major versions of code.
You can try to downgrade, if the second controller is not terminating live APs, but I cannot promise it will work.
Regular Contributor I
You should be able to downgrade, but I would upgrade the master controller instead.
We have Aruba 650 series,we downgrade Aruba OS 6.1.1.0 to Aruba OS 3.4.4.3, we have problem with Policy Enforcement Firewall Next Gen License (16 AP Support), error message Key contains limits that are not valid for ArubaOS. We want activation key working for Aruba OS 3.4.4.3. What should we do,we hope for best solution.
You should contact support, to geet a temporary license.
