Problem ViA EAP-TLS Ikev2
  • 1.  Problem ViA EAP-TLS Ikev2
    Posted Aug 09, 2017 05:07 AM
    We have some trouble setting up via with EAP-TLS authentication.
    Scenario:
    • We have distributed cert to users
    • Setup ViA profiles to look at our NPS server
    • The NPS server is up and we think everything is find but we get Reason code 22: The client could not be authenticated because the Extensible Authentication Protocol (EAP) Type cannot be processed by the server.
    • We are using usertemplate for clientcert and our nps server is using RAS IAS certtemplate. NPS are not a domaincontroller but domainmember
    I think have looked everywhere for a solution but now we are ready to give up.
    My question is if someone have one good solid guide to set up VIA with EAP-TLS verification throw windows NPS?
    This is the log from client:
    Aug 09 10:45:50.801  p3264  t2058  INFO anikeimpl  578  IKE PAcket Received
    Aug 09 10:45:51.208  p3264  t2058  TRACE ancert_mgmt  296  Enter CertificateLeafDNTest
    Aug 09 10:45:51.208  p3264  t2058  DEBUG ancert_mgmt  301  0 DN pair Configured
    Aug 09 10:45:51.208  p3264  t2058  INFO ancert_mgmt  311  DN test staus 0
    Aug 09 10:45:51.208  p3264  t2058  TRACE ancert_mgmt  312  Exit CertificateLeafDNTest
    Aug 09 10:45:51.209  p3264  t2058  INFO ancert_mgmt  344  Issuer Attribute type 38
    Aug 09 10:45:51.209  p3264  t2058  INFO ancert_mgmt  413  Issuer Attribute tierp-ZOOM2K8-CA
    Aug 09 10:45:51.213  p3264  t2058  INFO ancert_mgmt  450  Validate cert and its ancestor for basic constraint check
    Aug 09 10:45:51.213  p3264  t2058  ERROR ancert_mgmt  749  Query User Token failed reason = 5
    Aug 09 10:45:51.213  p3264  t2058  WARNING ancert_mgmt  585   Failed locating a logged on user, err= 5, Continueing..
    Aug 09 10:45:51.213  p3264  t2058  INFO ancert_mgmt  622  The size of the chain context is 72.
    Aug 09 10:45:51.213  p3264  t2058  INFO ancert_mgmt  623  1 simple chains found.
    Aug 09 10:45:51.213  p3264  t2058  INFO ancert_mgmt  624  Error Status code is 1
    Aug 09 10:45:51.213  p3264  t2058  INFO ancert_mgmt  628  This certificate or one of the certificates in the certificate chain is not time-valid.
    Aug 09 10:45:51.214  p3264  t2058  ERROR anike_mocana_cbh  1510  CHILD_SA [v2 I] failed
    Aug 09 10:45:51.214  p3264  t2058  INFO anike_mocana_cbh  1512  , status = -6012
    Aug 09 10:45:51.215  p3264  t2058  ERROR anike_mocana_cbh  1390    IKE_SA [v2 I] (id=0xa3b378f3) failed
    Aug 09 10:45:51.215  p3264  t2058  ERROR anike_mocana_cbh  1397  sending ike event
    Aug 09 10:45:51.215  p3264  t2058  ERROR anike_mocana_cbh  1402   IKE Phase 1 SA Failed status = -6012
    Aug 09 10:45:51.215  p3264  t2058  TRACE anikeimpl  302  EAP INFO Deleted EAP Session.
    Aug 09 10:45:51.215  p3264  t2058  DEBUG anikeimpl  531
  • 2.  RE: Problem ViA EAP-TLS Ikev2
    Posted Aug 09, 2017 05:53 AM
    Can you show us what the NPS policy looks like?
  • 3.  RE: Problem ViA EAP-TLS Ikev2
    Posted Aug 09, 2017 08:11 AM
    For information: We have found a solution :).
    Problem was that ViA client tried to use one expired ca-certificate on the workstation. One line in log from ViA-client said "invalid time" and that was probably this expired certificate.
    Deleted that certificate on the client and it runs now correct.
