Problem nanny reboot controller
  • 1.  Problem nanny reboot controller
    Posted Aug 01, 2013 06:11 PM
    I have a 3600 Controller with a AOS 6.2.1.3 and the problem is that each 1:20 hours it will reboot. I have seen the logs and I have got this:
    "Reboot Cause: Nanny rebooted machine - httpd_wrap process died."
    I know that Nanny is Process Manager is active and will start monitoring other processes and de Cause is If Reboot flag is enabled, system will reboot under certain conditions such as low memory and system critical process dying.
    I have tried to solve the problem with two diferents AOS (AOS 6.3.0.0. asd 6.2.1.3.) but the controller have present the same case
    Is there any way for disable this flag?
    #3600
  • 2.  RE: Problem nanny reboot controller
    Posted Aug 01, 2013 06:39 PM
    I have the same case
  • 3.  RE: Problem nanny reboot controller
    Posted Aug 01, 2013 08:37 PM
    Please open a support case ASAP.
