Problem when controller is disconnected
  • 1.  Problem when controller is disconnected
    Posted Jun 08, 2012 04:41 AM
    Hi there! I have this problem:
    when the controller is disconnected from the network, the access point will not work. I knew that the AP continue to operate at controller unplugged. Do you have any idea?
  • 2.  RE: Problem when controller is disconnected
    Posted Jun 08, 2012 08:04 AM
    Most of the AP's only work when the controller is up. If the controller is down then the AP will keep rebooting to try to reesablish a connection to the controller.  If you want AP's to work without a dedicated controller then one option I know about is using the IAP's which don't require a dedicated controller.
    Ian
  • 3.  RE: Problem when controller is disconnected
    Posted Jun 08, 2012 09:14 AM
    Thanks for reply. I have AP93, not IAP93. That is the problem? The supplier had assured me that AP93 worked independently of the controller.
  • 4.  RE: Problem when controller is disconnected
    Posted Jun 08, 2012 10:36 AM
    Yes, the IAP works independently of the controller.
