Problem with captive portal
Hi everyone,
I work on Aruba controller 6.0 and I want to create captive portal from WebUI.
I follow this doc : http://www.arubanetworks.com/vrd/guestaccessappnote/wwhelp/wwhimpl/js/html/wwhelp.htm#href=Chap4.html
and this too : http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/ about captive portal.
When I log on captive portal i arrived on the aruba controller and not the net.
I entered good dns and I redirect my captive portal.
Thank's for your consideration.
MaliqueVince
PS : Sorry for my bad english I'm french >.<
Re: Problem with captive portal
Bonjour!
So...in your configuration, the initial role must have the captive portal profile set.  The role must also allow DHCP and DNS to get to that page.  Is there an IP interface configured on the controller? Could you post the relevant config?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Frequent Contributor II
If you still get the captive portal after logging on..
It sounds like you might not get the correct role after login?
Either that or maybe you have put the captive portal ACL on your "logged-in" (guest)?
Just some thoughts on stuff to check :)
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Thank's for your resp,
I work on internal network in 192.168.X.0 /24.
the controller have an ip interface 192.168.X.254. I use the controller like a DHCP server.
For a test I put Public DNS 8.8.8.8.
Also, I work with a proxy server in my LAN 192.168.X.247.
I've got a rule for my proxy in the CP configuration.
What are you resolving to on the captive portal?  Try using an internal DNS or use the IP address in the URL field
Seth R. Fiermonti
Email: seth@hpe.com
it does not work with an internal DNS =(
I'm using my cp_prof in the filed default guest role and in the field default role the user role "guest-logon" with the configuration to my captive portal.
I check "User Login" and i put my proxy server configuration.
OK. do NOT use the CP prof in the guest role?JUST the guest-logon role
Seth R. Fiermonti
Email: seth@hpe.com
doesn't work with guest-logon indefault guest role -_-'
Guest-logon should be your initial role, not your guest role. Try putting allowall for the default guest role and see if you are able to get past the captive portal.
Tim Cappalli | Aruba Security
it's work when I put my proxy configuration in my customer host and when I use the following configuration
"Default Role : Guest-logon"
"Default Guest Role : My_cp_prof"
"proxy server configuration : @IP_proxy:3128"
But I don't want to configure my proxy in the host.
I would like the controller redirects to my proxy without entering the configuration in my machine.
Possible ?
