Contributor I
Problems with SMTP Controller for Guest Receipt
Hi Aruba Community,
I'm trying to configure the SMTP server on a controller with AOS 6.4.3.7 with several free SMTP servers but I can not send me an email when creating an account for guest. To configure it, I use the smtp ip that I get when I run the <nslookup relay-smtp.domain.com> (ex.: nslookup relay-smtp.gmail.com) command on CMD.
When I set the SMTP with my company smtp, it's working properly.
Any suggestions please.
Best regards,
Alberto.
Re: Problems with SMTP Controller for Guest Receipt
Your ISP could be blocking outbounds SMTP except to their own relays.
