Regular Contributor I
Problems with master backup controller configuration
Hi @ all,
I´ve a problem with the master and backup controller config.
I want to use my "old" aruba controller 651 as the master controller and my new 651er Controller as its backup.
Bouth controller running OS 6.3.1.2.
But I don´t get this work.
My controller1 Master IP: 192.168.25.10 vlan 25
My controller2 Backup IP: 192.168.25.11 vlan 25
VRRP: 192.168.25.100 vlan 25.
I configured it like in this howto : http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_UG/VRRP.php
So now the controller cant ping each other...
controller1
controller2
controller1
controller2
Have anyone an idea?
what is wrong?
Aruba
Re: Problems with master backup controller configuration
Try setting your Master VRRP to 10 on both controllers; not 1 and 2....it needs to refer to the Virtual Router ID on the controller that you want to use.
Also on the 1st controller, delete VRRP 1 if it is not in use (doesn't look to be as it as 0.0.0.0 as an IP).
AMFX | ACCX | ACDX | ACMX
Ok, I set the Master VRRP on both controller to 10.
I also delete the vrrp1 0.0.0.0 ...
Now the controller can ping each other,
when I go to the cli and do show master-red.
Both controllers corrent state is master:
controller1
controller2
Log Controller 1 Master
Do you have an idea why it don´t work?
Aruba
It looks like both controllers claim they are master for 192.168.11.100.   Run the following on each, they should have different priorities set.  Your preferred master should have a higher priority number (for example 110 vs. 100).  Also check to see what preemption is set at.
show vrrp 10
Ok, I looks like it has taken a little time and now it shows like it works. :-)
controlloer2
On my master controller at cli I take:
cfgm set sync-type complete
So far so good.
I also enabled the database sync on both controller.
At the backup controller are a few alerts:
The cfgm set sync-type complete command shows success in the master controller logs.
Have you an idea?
Aruba
OK good.   It looks like the backup does not have a PEFNG license on it?   Can you confirm?
show ap license-usage
If you are runnining 6.3, you can enable centralized licensing as well:  http://www.arubanetworks.com/techdocs/ArubaOS%206_3_1_Web_Help/Content/ArubaFrameStyles/New_Licenses/Multi__Network.htm
Ok, I think you are right, on the backup is no license.
I want to enable cenralized licensing.
If I´m right, I only have to enable it on the master controller right?
Have I configured it right? The Backup have no licenses on it yet and the alerts are the same.
I ´ve given a new IP for the license server IP adress, was that right?
This is what the backup controller says:
The checkbox can´t be checked to enable centralized lic. on the backup controller.
Master:
Aruba
That is correct, just wasn't sure if you had the master enabled.  In your setup, what is 192.168.25.101?     Your VRRP IP address for ID 10 is 192.168.25.100, isn't it?
I take this IP-adress for the license server (new ip adress)
the vrrp address is 192.168.25.100!
