Hi All,
We have 40Mhz enabled on 5Ghz on 3rd Floor and 20Mhz enabled on 2nd Floor. Previously 2nd Floor also was on 40Mhz but due to more number of APs we have disabled 40MHz there.
The 3rd floor AP signal strength is 12-18 dBm and can be heard in 2nd Floor as well.
So my question is, will it make any disconnection to the wireless clients who are connecting in 2nd Floor ?
Is it bad to mix up 20Mhz & 40Mhz on 5Ghz for same SSID ?
