I have a combination of 7205+207, the version is 6.5.3.7, use local captive portal authentication, connect to the external radius server, use the radius service automatic timeout after a period of use, the controller aaa test server is timeout, after a long time radius service The automatic recovery is normal. The second time this happens again, the customer powers off and restarts the controller, and the authentication is restored to normal. Now, what is the problem is not found. The following is the topology.
