last person joined: 10 hours ago
RAP 109 randomly getting E flag - Domain Mismatch
  • 1.  RAP 109 randomly getting E flag - Domain Mismatch
    Posted May 12, 2015 08:49 AM
    Hey Guys !
    Hoping you can help on this one...
    So we've had a few RAP 109's go into regulatrory domain mismatch mode the past few weeks. ( E Flag )
    This is a bit of an odd one as the RAP's in question have been working for fine on their own for months, then all of a sudden they get the E flag and stop broadcasting. Other RAP's on the site, also on the same controller are not affected at all.
    The trend i have noticed is that the RAP's in question seem to get moved into the AP Specific folder on the controller. When i remove the RAP from that folder and powercycle the RAP, it comes right back up again and broadcasts the SSID's
    In one or 2 cases, the issue has returned where i have repeated the process and they have come back up and seem stable
    Has anyone ever seen this before?
    Thanks in advance for any info :)
    Currently running version 6.3.1.5 on the controller
  • 2.  RE: RAP 109 randomly getting E flag - Domain Mismatch
    Posted May 12, 2015 09:03 AM
    HI,
    You said, RAPs are moved to a specific folder. you mean moved to "AP-Group" ?
    if they are moved to an other AP-group there is a chance for this domain mismatch.
    we can configure different "Regulatory Domain" for each of AP-group.
    As a work around, verify the Regulatory domain of the AP-group with which you have issue.
    for your ref:
  • 3.  RE: RAP 109 randomly getting E flag - Domain Mismatch
    Posted May 12, 2015 09:14 AM
    By Ap-specific , i meant the actual AP Specific tab ( As in the screen shot attached )
    These RAP's were originally in their intended AP Group, but the problem is, some of them seem to move into this " Ap Specific " group on their own and then they stop broadcasting ( E flag )
    I just hit the delete button on the RAP i want to get back online and once its powercycled, it comes back up
  • 4.  RE: RAP 109 randomly getting E flag - Domain Mismatch
    Posted May 12, 2015 10:54 AM
    It should not happened, AP can not change it's AP-group with out reprovision it. to know the reason you can use "show audit-trail | include <Apname>" this will give us some idea.
    Please feel free for any further help on this.
  • 5.  RE: RAP 109 randomly getting E flag - Domain Mismatch
    Posted May 14, 2015 04:03 AM
    chewbacca
    AP's dont move to ap-specific config (aka ap-name), it is not a group - it is an override to the AP group; it just means someone has decided to add some specific config.
    As it turns out, there is a bug in early 6.3.1.x that causes this exact issue if a RAP reboots and there is an ap-specific config existing and that config doesnt have a regulatory domain profile.
    Either remove the ap-name directives for now and reboot the AP, or upgrade to 6.3.1.x latest and it will be solved. I am not sure if you can just add the regulatory domain explicitly to each ap-name, you can try it.
    bug id for your reference is 98432, fixed in 6.1.3.6, but please only use latest 6.3.1.x if you upgrade.
    regards
    -jeff
