RAP issue Showing INACTIVE flag
I have RAP Access-Point  with controller ip 192.168.10.138 /114.143.10.14
scenario :
A) when i connect the RAP in campus area with following parameter.
1.Remote Access-Point
2.with FLAG  showing R
3.Group: Default
its working good here
B) when i connect the RAP in campus with following parameter.
2.when i change to group REMOTE_VAP
having following parameter
Ap systeam-Profile:
LMSIP:192.168.10.138 , BackLMSIP:114.143.10.14
but FLAG Indication is showing RI (R:Remote , I:Inactive)
Why it is showing Remote Inactive ?
Re: RAP issue Showing INACTIVE flag
 If you run "show profile-errors" is there any errors in your configuration?
This could could be due to a missing VLAN, invalid reg domain etc. Is the VAP correctly configured?
Also looking at your LMS IP, this is an internal address, should this be the case? I've seen sometimes the LMS IP is an internal address so the IPSEC tunnel is attempted to be established to this IP when it actually has to traverse an external IP range.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Aruba
Looks like the RAP can establish the IPsec tunnel; but not its LMS tunnel.   Reconfigure the LMS IP in the REMOTE_VAP group.
Either change it to the external IP or leave blank (if blank it will use the IP it was provisioned against).
AMFX | ACCX | ACDX | ACMX
