RAP
  • 1.  RAP
    Posted Dec 08, 2013 07:02 AM
    Dear community Engineers,
    Is there any other options to connect 2 branches via RAP without public IP in HQ?
    If there is what are the best practices ?
  • 2.  RE: RAP
    Posted Dec 08, 2013 07:55 AM
    What exactly you are trying accomplish ?
  • 3.  RE: RAP
    Posted Dec 08, 2013 08:15 AM
    I am trying to connect HQ to branch office to establish voice flow over VPN but unfortunately both ends don't have public IP they have
    DSL connection.
  • 4.  RE: RAP
    Posted Dec 08, 2013 08:30 AM
    Aren't able to reach the internet through that DSL line ? Because if that's the case you should be able to get a public IP address from from ISP
  • 5.  RE: RAP
    Posted Dec 09, 2013 08:58 AM
    I am trying to build a new connection is there any other solution rather than connecting via public IP???
  • 6.  RE: RAP
    Posted Dec 09, 2013 10:47 AM
    You could potentially have a standalone setup that doesn't have to communicate back to remote location like the Aruba instant .
    If you don't have a way to have a direct connection back to your controller on a remote location then there's isn't that many options available if you don't have a public ip to reach it
