RAP3 AOS Code
  • 1.  RAP3 AOS Code
    Posted Dec 13, 2012 10:42 AM
    Hi All,
    My MD gave my a RAP3 and asked me to configure it for him.
    Looking at the install guide it says a RAP3 required AOS 6.1.4.0 to operate as a RAP however there is no 6.1.4.x released under general availability. I can see 6.2 in early deployment but don't really want to deploy this on our production controller.
    Can someone let me know if AOS 6.1.4.x (or above) is still a requirement for RAP3s to operate as a RAP?
    James
  • 2.  RE: RAP3 AOS Code
    Posted Dec 13, 2012 11:11 AM
    I am currently using the 6.1.4.1 code for almost a month for our RAP3's and we haven't experience any issues the AOS it is located under the Technology folder , I have attached a screenshot
  • 3.  RE: RAP3 AOS Code
    Posted Dec 13, 2012 11:15 AM
    Ah ok. Thanks for letting me know.
    I only see the 6.1.3.4 Airgroup in Technology.. Will speak to my SE.
  • 4.  RE: RAP3 AOS Code
    Posted Dec 13, 2012 11:17 AM
    My bad, almost forgot.
    I had to open a TAC case and then they gave me access.
  • 5.  RE: RAP3 AOS Code
    Posted Dec 13, 2012 11:18 AM
    I think it is still a BETA code
  • 6.  RE: RAP3 AOS Code
    Posted Feb 12, 2013 04:48 AM
    RAP 3 is also supported in AOS 6.2.
