Occasional Contributor I
Random connectivity issues
I need to investigate connectivity issue.
Wifi client connected to AP225 under Aruba7210-US sw. Version 6.3.1.9
Randomly, few times a week, the client loses connectivity to the network. It is not able to ping even default gateway. Ip address assigned, system shows that it is connected to WIFI., but ARP shows that ARP of default gateway is incomplete.
Then  after a couple of seconds connection restores automatically.
No issues for another wifi clients, nothing suspicious in logs.
Please, give me some commands to investigate the issue more deep.
Re: Random connectivity issues
What kind of client is this?  Are you using authentication?
Client is Ubuntu.
Authentification - .1x using machine cert.
Is the problem happening with other clients...
Only one client reported.
Maybe you can enable client-side wifi debugging in Linux to see what is happening.
On the controller side, you can enable debugging on the controller like this:
config t
logging level debugging user-debug <mac address of client>
When the problem happens, you type "show log user-debug 100" to see what happened at the time.  The controller debug along with the client-side debug should give us a clue what is happening.
We also have a suite of troubleshooting docs and related commands based on issues.  See here:
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=17541
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Around a time when issues happened, I found following errors in logs:
|ids| AP: Block ACK DoS Attack: An AP detected a data frame which indicates a possible Block ACK DoS Attack. The frame from (mac address of the client) to (dest mac) (BSSID of my AP) on CHANNEL 100 with SNR 49) is outside the current sequence number window, and thus may be dropped.
The client is legitimate. How to avoid such error for the particular client?
dzimin wrote:
Those messages can be the result of false positives.
Linux drivers also can be less well maintained than Windows and other operating systems.  If you said that this problem occured with all of your clients, I would look to the system.  If it occurs with a single client, I would say to take another look at the client to see if there are any more up to date driver fixes.  Which client adapter is it?
Debug for client runs for a week, disconnection happens but nothing in the debug logs.
I noticed only gap in output. I.e disconnection happened at 12:14:40
Logs:
Nov 4 11:58:52 :522245: <DBUG> |authmgr| user_age() called for MAC xx:xx:xx:xx:xx:xx IP xxxx:xxxx:xxxx:xxxx:xxxx.
Nov 4 11:59:56 :522245: <DBUG> |authmgr| user_age() called for MAC xx:xx:xx:xx:xx:xx IP xxxx:xxxx:xxxx:xxxx:xxxx.
Nov 4 12:01:00 :522245: <DBUG> |authmgr| user_age() called for MAC xx:xx:xx:xx:xx:xx IP xxxx:xxxx:xxxx:xxxx:xxxx.
Nov 4 12:02:04 :522245: <DBUG> |authmgr| user_age() called for MAC xx:xx:xx:xx:xx:xx IP xxxx:xxxx:xxxx:xxxx:xxxx.
Nov 4 12:03:08 :522245: <DBUG> |authmgr| user_age() called for MAC xx:xx:xx:xx:xx:xx IP xxxx:xxxx:xxxx:xxxx:xxxx.
Nov 4 12:18:03 :522245: <DBUG> |authmgr| user_age() called for MAC xx:xx:xx:xx:xx:xx IP xxxx:xxxx:xxxx:xxxx:xxxx.
Nov 4 12:19:06 :522245: <DBUG> |authmgr| user_age() called for MAC xx:xx:xx:xx:xx:xx IP xxxx:xxxx:xxxx:xxxx:xxxx.
So DBUG user_age() messages appears each minute and then gap for 15 minutes
