Occasional Contributor I
Randomly AP Reboot !! Urgent
Hi
I have Aruba 7005 controller and and IAP 205 . ArubaOS version 6.4.2.8. My problem AP 7 out of 15 starts reboot every 3-4 hours. I trying 3 different arubaos (6.4.1.0 - 6.4.3.2 and now 6.4.2.8) and problem continues. AP's connected same poe switch. There is no information debug and crash log. Only one log
94:b4:0f:cc:f1:3c@192.168.0.46 nanny|  Reboot Reason: No reboot message found . 8 Ap never restart.  Only 7 ap same time rebooting. What could be problem?
Re: Randomly AP Reboot !! Urgent
What is the power budget for your switch? Does the switch show anything in its logs?
Tim
Tim Cappalli | Aruba Security
What poe switch do you have.
juniper ex4200 24 port poe switch.
I do not think problem is switch because other 8 ap not reboot.
How many APS do you have on the switch?
totally 15 ap on same switch
Try to move the access points that keep rebooting to a different switch. No reboot reason normally means that the power was removed from them.
Frequent Contributor II
Hi
Don't forget to check cables, Layer 1 must be in order for AP's to stay up.
Errors on Layer 1, might trigger the switch to cut power (crc etc).
This should show up in the switches log btw.
Roar
Did you ever find the solution to this? I'm having the same problem and I know it's not a cabling or switch problem. Seems more likely in the AP-105s than any others..
