Frequent Contributor II
Rap 2 IL Flag on Controller
I have a customer that has 3 650 controllers, one master and the rest slave.  He has purchased the max license's for this environment and is not using all of them "See Attach Screen Shot's" We are trying to provision a Rap 2, eventually it shows up on the controller with a IL flag which does not make sense.  I unplugged the Rap and plug in a spare AP 105 that he has and it finds the controller and I am able to provision it with no issue or flag's.  Any suggestions?
Re: Rap 2 IL Flag on Controller
How many APs do you have attached to that controller ?
The 650 has a limitation , please do a show ap active
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Here is what the customer just pulled for me.
Active AP Table
They need the output of "show ap database"
OK TAC is looking into now.
Contributor II
1.use AOS 5.0
2. or config the rap2 as remoteAP mode.
Aruba
In 6.2+ code on the 600 series, capacity is now CAP=RAP. There is no longer a multiplier for RAP's coming in over IPsec.
| Adam Kennedy, Systems Engineer - adamk@hpe.com
| Service Providers – Aruba, an HPE Company
| Twitter: @adam8021x | Airheads: akennedy
