last person joined: 11 hours ago
Reachability Problem
  • 1.  Reachability Problem
    Posted Apr 27, 2014 01:58 PM
    Hello everyone
    I have Aruba3600 controller connected to core-switch, I have followed the procedure defining vlans, gateway,licenses, trunk/access ports ...etc.
    I've connected the trunk port from Aruba controller to tagged port in the same vlan on core-switch
    when I ping the gateway from Aruba controller or ping the aruba controller ip from core-switch I got unrechablity message on both
    if I connect from Aruba to core-switch with access port it will be pingable but on trunk port not
    on the following screenshot I am trying to trace the gateway (10.18.1.1) from aruba controller (10.18.1.10)
    Aruba controller is on the same subnet.
    also I've got a CDATA error as in the screenshot and I don't know why ! I have inserted the license already in the aruba and tried 2 firmware versions (3.3 and 6.2)
    any hint please, thanks in advanced
    Regards
  • 2.  RE: Reachability Problem
    Posted Apr 27, 2014 01:59 PM
    did you reboot after adding the licenses?
  • 3.  RE: Reachability Problem
    Posted Apr 27, 2014 02:02 PM
    yes more than one time
  • 4.  RE: Reachability Problem
    Posted Apr 27, 2014 02:07 PM
    Okay.  The licenses have nothing to do with the trunk.  Is the native VLAN on the Cisco side the same as the native VLAN on the Aruba side?  Please post the configuration for both sides.
  • 5.  RE: Reachability Problem
    Posted Apr 27, 2014 03:47 PM
    In addition to cjoseph suggestions make sure of the following :
    - VLANs are trusted
    - your default gateway : show IP default-gateway or show IP route
  • 6.  RE: Reachability Problem
    Posted Apr 27, 2014 04:01 PM
    maybe I didn't explain well :) :
    . I mentioned the license just because I read here about this error "role authenticated is unknow" related to license .
    . For both sides configurations:
    Core Switch
    vlan 18 name Wifi-Managment
    tagged ethe 1/7                                         -----------------  Aruba <<>> Core-Switch
    interface ve 18
    ip address 10.18.1.1/16
    Aruba
    (Aruba1) #show interface gigabitethernet 1/2
    GE 1/2 is up, line protocol is up
    Hardware is Gigabit Ethernet, address is 00:0B:86:61:B3:CB (bia 00:0B:86:61:B3:CB)
    Description: GE1/2 (RJ45 Connector)
    Encapsulation ARPA, loopback not set
    Configured: Duplex (Full), speed (1000 Mbps)
    MTU 1500 bytes, BW is 1000 Mbit
    Last clearing of "show interface" counters 0 day 4 hr 43 min 47 sec
    link status last changed 0 day 4 hr 20 min 59 sec
    242859 packets input, 48167266 bytes
    Received 121342 broadcasts, 0 runts, 0 giants, 0 throttles
    3 input error bytes, 0 CRC, 0 frame
    27264 multicast, 121517 unicast
    136642 packets output, 31623314 bytes
    0 output errors bytes, 0 deferred
    0 collisions, 0 late collisions, 0 throttles
    This port is TRUSTED
    (Aruba1) #show vlan 18
    VLAN CONFIGURATION
    VLAN Description Ports AAA Profile
    18 Management GE1/0-3 N/A
    iinterface gigabitethernet 1/2
    description "GE1/2"
    trusted
    trusted vlan 1-4094
    speed 1000
    duplex full
    switchport mode trunk
    switchport access vlan 18
    switchport trunk native vlan 18
    interface vlan 18
    ip address 10.18.1.10 255.255.0.0
    ip default-gateway 10.18.1.1
    uplink wired vlan 18
    uplink enable
    ip dhcp pool pri
    default-router 10.18.1.1
    lease 1 0 0 0
    network 10.18.0.0 255.255.0.0
    authoritative
    service dhcp
  • 7.  RE: Reachability Problem
    Posted Apr 27, 2014 04:08 PM
    On the Aruba side, what is the output of "show trunk"? What is the Cisco side of the configuration?
  • 8.  RE: Reachability Problem
    Posted Apr 27, 2014 07:43 PM
    (Aruba1) #show trunk
    Trunk Port Table
    Port         Vlans Allowed       Vlans Active      Native Vlan
    GE1/2            ALL                   1,14,16,18              18
    on the Brocade Switch it is connected to Vlan 18 through TAGGED port (ethernet 1/7)as a trunk port bettween aruba and the core-switch
    Core Switch
    tagged ethe 1/7
    (Aruba1) #traceroute 10.18.1.1
    Tracing the route to 10.18.1.1 ....
    1 * 10.18.1.10 (10.18.1.10) 1010.164 ms UNREACHABLE *
    2 10.18.1.10 (10.18.1.10) 1010.204 ms UNREACHABLE * 1000.075 ms UNREACHAB
    E
    (Aruba1) #show ip route
    Codes: C - connected, O - OSPF, R - RIP, S - static
    M - mgmt, U - route usable, * - candidate default, V - RAPNG VPN
    Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
    Gateway of last resort is 10.18.1.1 to network 0.0.0.0 at cost 1
    S* 0.0.0.0/0 [1/0] via 10.18.1.1*
    C 172.16.0.0/24 is directly connected, VLAN1
    C 10.18.0.0/16 is directly connected, VLAN18
    C 10.14.0.0/16 is directly connected, VLAN14
    C 10.16.0.0/16 is directly connected, VLAN16
  • 9.  RE: Reachability Problem
    Posted Apr 27, 2014 08:29 PM
    all thanks for Mr. cjoseph and Mr. victorfabianall  :)
    solution was to put any other vlan than 18 as a native
    Trunk Port Table
  • 10.  RE: Reachability Problem
    Posted Apr 27, 2014 04:11 PM
    Wait: on the Aruba side Vlan 18 is the native vlan, but on the Cisco side it is tagged? Both sides have to match: both sides have to have vlan 18 as native or untagged or both sides need to have it tagged and allowed...
