Reboot Cause: Hardware Watchdog Reset
Had a controller randomly reboot after being up for a very long time. Don't know what the error is related to, was hoping someone might have some insight. I already have a TAC case open, but didn't want to sit around and wait. Below is the switchinfo from CLI:
(I-1-SA) #show switchinfo
Hostname is I-1-SA
Console Baudrate: 9600
Location not configured
System Time:Wed May 25 14:54:45 EDT 2016
ArubaOS (MODEL: Aruba7220-US), Version 6.3.1.16
Website: http://www.arubanetworks.com
Copyright (c) 2002-2015, Aruba Networks, Inc.
Compiled on 2015-03-31 at 23:37:56 PDT (build 49356) by p4build
ROM: System Bootstrap, Version CPBoot 1.2.1.0 (build 39183)
Built: 2013-07-26 04:57:47
Built by: p4build@re_client_39183
Switch uptime is 1 days 5 hours 43 seconds
Reboot Cause: Hardware Watchdog Reset (Intent:cause:register ee:ee:50:4)
Supervisor Card
Processor (XLP432 Rev B1 (Secure Boot) , 1000 MHz) with 7381M bytes of memory.
32K bytes of non-volatile configuration memory.
7744M bytes of Supervisor Card system flash.
Config File: default.cfg
Boot Partition: PARTITION 1
VLAN1 is up line protocol is down
Hardware is CPU Interface, Interface address is 00:1A:1E:00:EA:88 (bia 00:1A:1E:00:EA:88)
Description: 802.1Q VLAN
Internet address is 172.16.0.254 255.255.255.0
IPv6 Router Advertisements are disabled
Routing interface is enable, Forwarding mode is enable
Directed broadcast is disabled, BCMC Optimization disabled ProxyARP disabled Suppress ARP enable
Encapsulation 802, loopback not set
MTU 1500 bytes
Last clearing of "show interface" counters 1 day 5 hr 0 min 43 sec
link status last changed 1 day 5 hr 0 min 43 sec
Proxy Arp is disabled for the Interface
switchrole:master
Configuration unchanged since last save
No crash information available.
No kernel crash information available.
Michael Haring
ACMP, ACCP, BCNE, CCENT, Palo Alto ACE 7.0
Re: Reboot Cause: Hardware Watchdog Reset
You need to 100% open a case for this.  It could be anything.
Absolutely, I do have a TAC case opened and escalated, however, I was hoping someone had a similar failure that could shed some light on a possible cause.
Michael Haring
Hardware Watchdog Reset is very generic, and the causes can vary considerabily based on hardware, software and configuration.
