Hi Airheads,
I'm reposting this issue because still do not know how to solve this problem:
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Redirect-to-ClearPass-captive-portal-ip-issue/m-p/197711
I appreciate your ideas and comments. Thank you in advance,
Why don't you just source nat the HTTPS/HTTP and DNS traffic directed to ClearPass using an internal address
Let me try it and i will comment you how it works. Thank you very much.
That's the IP address of the controller and I use it to source nat the HTTP/HTTPS traffic
Then you can apply it to your guest-logon role
