Contributor II
Remote AP Not Working
Hi all,
I'm struggling to get my first remote AP working correctly. I've tried following the various guides and the documentation and have progressed...but it's still not showing up.
At this point, by looking into the logs, I can see that it's making an IKE connection with the controller, but it never progresses enough. I've attached the logs.
This is an IAP-205H converted to a campus AP, then provisioned as a RAP on our master/local controllers running 6.4.
Thanks for any pointers, I thought this was going to be much easier than it was (or I should have just followed the darned wizard...)
--Ben
Re: Remote AP Not Working
Make sure in the ap-group, in the AP system profile, there is no LMS-IP
Contributor II
Whoops, there was the internal addresses listed in there, and I have removed them.
Will I need to reset the AP and provision it again, or will it pick up on that automatically?
Just reboot it.
Contributor II
Thank you! That did it! I can't tell you how much time I spent fighting with this yesterday.
