Remote users Amigopod
  • 1.  Remote users Amigopod
    Posted Aug 13, 2012 08:23 PM
    Hi everyone,
    I've some RAP's when i provisioned locally the users are getting Amigopod page also getting authenticated by clearpass.
    But when i provisioned the RAP's in public, the users are getting IP address from local dhcp server but not able get Amigopod page.
    When i checked the firewall hits all the users are getting into default role(authenticated) not getting an amigopod profile.
    aaa profile "Amigopod-AAA"
       initial-role "guest-logon"
       authentication-dot1x "default"
       dot1x-server-group "Amigopod"
       radius-accounting "Amigopod"
       radius-interim-accounting
       rfc-3576-server "192.168.0.29"
    user-role guest-logon
     captive-portal "Guest-Amigopod"
     access-list session Amigopod
     access-list session captiveportal
     access-list session logon-control
    aaa authentication captive-portal "Guest-Amigopod"
       redirect-pause 3
       login-page "https://192.168.0.29/Login.php"
       welcome-page "http://www.transguardgroup.com"
       switchip-in-redirection-url
    user-role guest
     access-list session https-acl
     access-list session dhcp-acl
     access-list session dns-acl
     access-list session split
    Kindly advise where am doing mistake?
  • 2.  RE: Remote users Amigopod
    Posted Aug 13, 2012 09:35 PM
    Does the AP end up in the same ap-group when it is internal vs. external?
  • 3.  RE: Remote users Amigopod
    Posted Aug 14, 2012 12:42 AM
    Yeah the same Group....
    wlan virtual-ap "TG_Camps"
       aaa-profile "Amigopod-AAA"
       ssid-profile "TG_Rap-ssid_prof"
       vlan 103
       forward-mode split-tunnel
  • 4.  RE: Remote users Amigopod
    Posted Aug 14, 2012 04:44 AM
    When you say "provisioned locally" what do you mean?
  • 5.  RE: Remote users Amigopod
    Posted Aug 14, 2012 11:38 PM
    When i connected the RAP in local network it was working, when it was in over public network it won't.....
    And i found the issue... actucally portchannel is configured on controller for two ports which is connected to HP A series switch when i disabled portchannel it's working fine....... STRANGE behaviour!!!!
    Any idea that we need to check aruba confign coz switch guy was telling everything fine from his side???
