Required best AP for project
  • 1.  Required best AP for project
    Posted Jul 05, 2016 02:53 AM
    Hi all
    I am planing for a project and want best AP for that.
    Project details:-
    two buildings A and B. Distance between them is 1 km.
    A is main office with all networking equipment and pbx.
    want network connectivity for B on WLAN.
    Please help me in this case.
    Regards
    Pank
  • 2.  RE: Required best AP for project
    Posted Jul 09, 2016 10:12 AM
    What kind of environment is betwwen building A and B?
    How many users are in Building B and what kind(s) of main applications do they need?
  • 3.  RE: Required best AP for project
    Posted Jul 11, 2016 07:09 AM
    Thank you for reply
    LOS is clear.
    50 users in building B
    Application:- IP phones.
    Regards
    Pankaj
  • 4.  RE: Required best AP for project
    Posted Jul 11, 2016 08:32 AM
    You best performance and setup that will provide the highest bandwidth with the least amount of interference will be a pair of (I)AP-274s with ANT-2x2-5314 30deg 14dBi antennas. These are narrow PtP antennas that will provide the most interference rejection due to their narrow beamwidth and will be the highest gain. You will have to run a minimum of HT40 to carry 50 concurrent voip calls.
  • 5.  RE: Required best AP for project
    Posted Jul 14, 2016 05:46 AM
    Hi
    Thank you for providing solution.
    Regards
    Pankaj
