S1524 not power the 115 APs connected to it
  • 1.  S1524 not power the 115 APs connected to it
    Posted Jan 04, 2014 06:30 AM
    I think it should be a configure problem, any hint will be helpful, thanks alot.
    It is one of the 16 S1524  I recently installed in one shopping mall. All switches have the same poe profile configued. show poe interface command give the following output
    GE0/0/0
    GE0/0/0: Administratively Enable, Port status: Off
    Maximum power: 30000 mW, Power consumption: 0 mW
    Port voltage: 0 mV, Port current: 0 mA
    PD class: Class-0, Priority: Low, PSE port status: Off, PD detection in progress
    GE0/0/1
    GE0/0/1: Administratively Enable, Port status: Off
    PD class: Class-4, Priority: Low, PSE port status: off, (code=24)
     ge0/0/0 didn't connect to device, while ge0/0/1 connnected to a 115 AP
    It seems to me that the S1524 has communicated to the AP, and decided that it's a Class-4 device, but due to some reason, it didn't power it. and What does the "code=24 " mean?
    There are 18 APs connected to it, all of them are not powered.
  • 2.  RE: S1524 not power the 115 APs connected to it
    Posted Jan 04, 2014 09:57 AM
    What how is your POE profile configured?
  • 3.  RE: S1524 not power the 115 APs connected to it
    Posted Jan 04, 2014 05:21 PM
    part of poe-profile
    interface-profile poe-profile "default"
    interface-profile poe-profile "poe-factory-initial"
       enable
     how it is applied to port
    interface-group gigabitethernet "Access"
       apply-to 0/0/0-0/0/23
       lldp-profile "lldp-on"
       switching-profile "Access"
    interface-group gigabitethernet "default"
       apply-to ALL
       lldp-profile "lldp-factory-initial"
    All 16 switches have the same configuration with regard to  this part.
    In the first several days after I had installed it, this switch had no problem. Last week, when I occasionally logged into the AC, I noticed that APs on this switch is down and then came back in 10-20 minutes. Maybe it is indeed a hardware failure.
    I will post the output of show inventory later when I have access to the switch.
  • 4.  RE: S1524 not power the 115 APs connected to it
    Posted Jan 04, 2014 11:11 AM
    Can you provide the output of "show inventory" and "show poe controller"?
    Best regards,
    Madani
  • 5.  RE: S1524 not power the 115 APs connected to it
    Posted Jan 05, 2014 03:30 AM
    show inventory
    #show inventory
    Show Inventory
    System Card Slot        : 0
    SC Serial #             :
    SC Model Name           : ArubaS1500-24P
    HW MAC Addr             :
    CPLD Version            : (Rev: 28)
    PoE Firmware Version    : 2.4.8 (Build: 48)
    CPU Assembly #          :
    CPU Serial #            :
    Power Supply            : Present (580W)
                            : 12V System Voltage Ok
                            : 56V PoE Voltage Ok
    System Temperature      : CPU Temp                : 47  C
                            : Mid Temp                : 45  C
                            : DPE Temp                : 54  C
                            : Ambient Temp            : 24  C
    System Voltages         : 12000mV Sense           : 12062.5 mV
                            : 5000mV 5VDD             : 5000.0 mV
                            : 3300mV Sense            : 3300.0 mV
                            : 900mV CPU               : 935.5 mV
    System Fan Tachometers  : Power Supply Fan 0      : 3901  RPM (Low Speed)
                            : Power Supply Fan 1      : 3918  RPM (Low Speed)
                            : FAN 0                   : 3474  RPM (Low Speed)
                            : FAN 1                   : 3379  RPM (Low Speed)
     show poe controller
    #show poe controller
    Linecard  PowerBudget(W)  Power Consumption(W)  GuardBand(mW)  PoE Management
    0         400             0                     11000          Dynamic
  • 6.  RE: S1524 not power the 115 APs connected to it
    Posted Jan 05, 2014 06:23 AM
    Last Friday, I replaced the "broken" switch with a new one, reconnect all the wire. The switch did power all the APs one the initial boot. Then I pasted the configure to the switch, reloaded it and left.
    This afternoon, I came back and found that the new switch didn't power the APs either.
    This time I have plenty of time, so I did some more test.
    1. boot from another partition with older firmware. (Not help, I finally succeeded with the "original" newer image)
    2. write erase all, then reload. (Seems not help)
    3. In initial setup, change the country code to US instead of CN (Seems not help)
    4. There is one port connected to an old switch owned by customer, but I don't know it's brand and type. After reload, waiting for a while, with all copper wire unplugged except the one connected to the customer's switch, I unplugged the last one and then plugged the wire which connected to an AP on my hand,  the red led flashed on the AP immediately, the led on switch port began to blink. I plugged another wire which connected to an AP on site, waiting a little longer, the switch port led blinked too. I connected all the wire, all aps were  powered. I reloaded the switch, all aps were powered soon after the user prompt appeared.
    I can not repeat the problem again, at least in this afternoon. No matter whether I plug the wire connecting to the old switch or not, all aps can be powered after reload.
    I clean the configure file a little after all this
    1. I erased the configuration and restore the configure with necessary command only, not just paste all stuff in the backup configure file
    2. Execute "Poe-profile "default"" in "interface-group gigabitethernet "default""
    3. In "interface-group gigabitethernet "Access"", excluded the port connected to the old switch. So it is admin disabled on Poe.
    I'm not sure that it's me who make the switch work again, or the switch just recovery by itself. I will update this post if I run into this problem again.
  • 7.  RE: S1524 not power the 115 APs connected to it
    Posted Jan 05, 2014 02:05 PM
    Sanborn,
    I'm glad you got things up an running again.
    I did speak with Engineering and they have indicated that "(code=24)" indicates that we're recieving voltage inbound to the switch through the ethernet port. If possible at some point in the future, could you find out what this third party switch was? Also on what swithport?
    Best regards,
    Madani
