Hi all!
I have following situation:
Hardware & License
1 x ARUBA WLC 7030 (in standalone mode, Software: 8.0.0.0)
AP Capacity License
Problem
I try to create a SSID with Captiveportal Authentication for Guests with the Wizzard (they should only accept the Terms and Conditions)!
In the last Step (Access) there is a no editable field with "GuestTEST-guest-logon"
Then i click finish and get the following Error-Message:
% Invalid input detected at '^' marker. Error: Role 'guesttest-guest-logon' is Unknown Virtual AP profile "GuestTEST" does not exist.
I have also tried it with OS 8.1.0.1 and had the same problem?
Is this a BUG? Has anyone the same problem & how was it fixed?
thx for help
