SSID Steering (no band steering)
  • 1.  SSID Steering (no band steering)
    Posted Oct 19, 2017 10:30 AM
    We have multiple SSIDs, but certain SSIDs (used for lab-setups) are only available as an extra on selected APs (in those labs). Clients can connect to the regular SSID and the lab-SSID so both networks get configured in the client's settings.
    Once the client walks out of the lab, the WiFi-signal doesn't stop at the door. Even closer to APs broadcasting only the default set of SSIDs, the client can be connected to the lab-SSID even with a poor signal. Is there a way to "SSID-steer" this client to a non-lab SSID when it's stronger?
    Disconnecting clients after x amount of time to nudge them to the other network isn't a desirable solution.
  • 2.  RE: SSID Steering (no band steering)
    Posted Oct 19, 2017 10:53 AM
    There is not a way to do that, because the client makes that decision.  There is a knob called the local-probe request threshold, which does not allow a client to associate if the signal strength is too low, but it does not help for a client that is already associated.
  • 3.  RE: SSID Steering (no band steering)
    EDIT:  If you can afford it, maybe you should look into getting an RF chamber...
