SSID disappears from users with Atheros adapters
  • 1.  SSID disappears from users with Atheros adapters
    Posted Jan 23, 2017 12:26 PM
    Since upgrading 7220's to 6.5.0.3, Users with Atheros adapters are having problems where the SSID will disappear and come back and then go away again.  The common denominator is Atheros.
    I have updated the driver, turned off and back on the adapter and it still will not list the SSID.  I can go to the location with my device and connect everytime.
  • 2.  RE: SSID disappears from users with Atheros adapters
    Posted Jan 23, 2017 12:29 PM
    Any more details on the configuration of that SSID?  Encryption?
    Any more details on the specific client with the Atheros Adapter?
    Does this happen on a single band or dual bands?
    Do you have a screenshot of the Channel Utilization on the Dashboard?
  • 3.  RE: SSID disappears from users with Atheros adapters
    Posted Jan 23, 2017 12:37 PM
    The SSID is open. The user and/or users are windows 7 or above.  It seems to be happening on 2.4ghz. The channel utilization shows to be good for the areas where the users are.  I have a TAC case open but wanted to see if anyone else is having the same problem.
  • 4.  RE: SSID disappears from users with Atheros adapters
    Posted Jan 23, 2017 02:07 PM
    TAC is the best way to go.  There are simply too many things to check.
    I would make sure that you are configured as close to defaults as possible which means:
    - disable 802.11r
    - disable 802.11k
    - disable 802.11v
    - do not use local probe request threshold
    - use the default rates
    UPDATE 6/2018 -  The updated RF and Roaming Optimization Validated Reference Design Guide (VRD) has been published and has updated recommendations about enabling 802.11v, k and r in user networks.  The VRD can be found here: http://community.arubanetworks.com/t5/Validated-Reference-Design/RF-and-Roaming-Optimization-for-Aruba-802-11ac-Networks/ta-p/432994
