SSL cert not working
  • 1.  SSL cert not working
    Posted Jul 16, 2018 09:36 AM
    Hi
    Having an issue with an SSL cert which I want to use for the Captive portal on Aruba OS 8.2.1 running as a VMC
    Steps done:
    - CSR generated from the VMC sent to the CA
    - received signed cert back  ( see attached)
    - uploaded it onto the VMC - saved it as a PEM server cert
    -Went to General setings and changed the default captive portal cert to the new cert called "Aruba" ( see attached)
    - the CN specified on the cert has a DNS record pointing to the IP address of the VMC
    However when I get redirected to the portal it still comes up with the default expired cert securelogin.arubanetworks.com
    What am I missing/doing wrong, any ideas ?
    thank you
  • 2.  RE: SSL cert not working
    Posted Jul 16, 2018 09:44 AM
    1. You should not be creating a DNS entry. Remove that.
    2. What is the output of show datapath fqdn?
  • 3.  RE: SSL cert not working
    Posted Jul 16, 2018 09:55 AM
    Hi
    Okay removed it
    see below:
    Datapath FQDN Entries
    192.168.100.216
  • 4.  RE: SSL cert not working
    Posted Jul 16, 2018 09:58 AM
    Then the captive portal cert did not apply correctly. Try selecting default, saving and then reselecting your certificate.
  • 5.  RE: SSL cert not working
    Posted Jul 22, 2018 06:19 PM
    Hi Tim
    Okay found my initial problem but have a couple of more questions
    My full setup is 2x VMM and 2x VMC both layer 2 using VRRP for failover
    My problem was that I  generated the CSR from the VMM so although the Cert uploaded to the VMC, the VMC still referenced the old securelogin cert, that why I I think the FQDN would not change to the new CN.
    So I generated a CSR from the managed network group  where both my VMC were added, and when I clicked view current cert is shows me the new cert I generated on both VMC's
    I uploaded the signed cert from the CA and came across the following:
    On only the primary VMC it shows the FQDN change to my new CN the backup VMC still shows the securelogin CN
    I had to add the DNS entry back on my local DNS server otherwise I get an unable to resolve my new CN
    So as long as user traffic terminates on the primary VMC and I kept my DNS record in it works
    So questions 1
    Do I need to generate a CSR and purchase a certificate for each of VMC I have in a cluster ?
    questions 2
    You mention I should remove the DNS entry, please can explain how this should work if I remove it?
    thank you for all the assistance
  • 6.  RE: SSL cert not working
    Posted Jul 23, 2018 09:17 AM
    Do your CSR on another box.
    Once you have the siged cert, combine it with the key and intermediate into a PFX/PKCS12 file and import it at /md and then set the captive portal cert at /md.
    The FQDN is a virtual name and thus should not be in DNS.
