If you specify the vlan is the ssid settings, you'll need a trunk port for your APs.
Based on what you've said, for your APs, it would be trunk port (vlan 10,20), with vlan 20 to be the native vlan. The APs will come up and get an ip in the data centre vlan (20), but the clients will be place in vlan 10.
Hope that helps.
