Occasional Contributor I
Setting Up Series 300 Campus APs for DHCP in Multiple VLANs
Where can I find information, or "How To..." guides on setting up "Series 300" Wireless Campus Access Points to issue DHCP addresses in multiple VLANs?
Re: Setting Up Series 300 Campus APs for DHCP in Multiple VLANs
You honestly would want an external DHCP server in that situation.  The internal DHCP server on instant is fairly rudimentary and should only be used for guest networks.
