Hi Everyone,
First off, I really appreciate all of the help from this community. I haven't asked a lot of questions, but I've found a lot of answers here.
I'm just reading up on setting up High Availability:Fast Failover and am noticing that it does not work in locally-bridged mode (according to the link). For a client of mine, the idea was to have one controller at each of their two data centers in an HA:FF configuration and then set the APs at their respective offices to do local drop-off...doesn't look like that's going to work out. As far as I know, if you're not doing HA:FF, the HA model is VRRP, which wouldn't work across L3 boundaries. How would I go about configuring HA between two controllers on separate layer 3 segments and then still be able to configure the APs at a third location (their office) to do local drop off?
http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/VRRP/HighAvFastFailover.htm
