Signal Quality
This thread has been viewed 16 times
  • 1.  Signal Quality
    Posted Jan 18, 2013 12:51 PM
    Good Day,
    If the connected client has a signal quality of - does that mean that it could not be measured, or is it below a limit? AMP™ 7.5.7
  • 2.  RE: Signal Quality
    Posted Jan 18, 2013 02:28 PM
    Typically, you might see a '-' for signal quality for clients that have not yet been associated/authenticated.  A common case is if the user is in the 'logon' role.  You may also see this frequently from traps that convey signal on an irregular basis.  Polling the controller again may yield an update that populates the signal quality.
