Slave settings not updating correctly from master controller
Long story short, I had to change my RADIUS shared secret on my NPS server recently, and when I update the secret on my master controller, it never changes on the second controller. Users trying to authenticate through this controller to the RADIUS server are denied access because the RADIUS secret is incorrect. Anyone know how I can change this on the slave controller? The options are all greyed out when I view the RADIUS server settings.
Thanks!
Aruba
Re: Slave settings not updating correctly from master controller
Assuming the controllers are talking to one another, when you click Save Configuration, it will push the change to all the local controllers.
If you did this already, run show switches to see if the local is visible.
AMFX | ACCX | ACDX | ACMX
Save Configuration worked perfectly.... thank you very much.
