last person joined: 10 hours ago
Switch alert
  • 1.  Switch alert
    Posted Apr 28, 2016 05:57 AM
    I have set up the S1500 switch, but the status led have blinking in red continuously.
    The alert is inline power detected on Ge0/0/4
    What does this means?
  • 2.  RE: Switch alert
    MVP
    Posted Apr 28, 2016 03:26 PM
    Is GE0/0/4 uplinked to something? If so, what?
  • 3.  RE: Switch alert
    Posted Apr 28, 2016 10:06 PM
    Sorry
    What command should I type or where should I check?
    I have connected the S1500 switch port1 to the router. Will this affect?
  • 4.  RE: Switch alert
    MVP
    Posted Apr 29, 2016 09:46 AM
    If the device is running LLDP you can try "show lldp neighbors". Also do a "show port status" i believe on the S1500 to see if Ge0/0/4 is up.
    In the mean time, opening a support case with Aruba would also
    he a good idea as they can provide remote assistance.
