Throughput problem with Aruba 7220
  • 1.  Throughput problem with Aruba 7220
    Posted Apr 11, 2016 03:03 PM
    Hi all,
    I need some help with Aruba 7220 controller and APs which connected to this controller. We have got an Aruba 7220 controller. We are using AP-105, AP-93 and IAP-225(With controller mode) in production environment. The majority of Access Points are AP-105. As you can see below screenshots we have a throughput problem. The throughput cuts out occasionally.  When the throughput dropped suddenly, the clients continue to the controller but the clients can't access to internet.
    Any help or guidance would be greatly appreciated.
    Here are some relevant details for your info:
    #show version
    ROM: System Bootstrap, Version CPBoot 1.2.3.0 (build 43722)
    Built: 2014-05-13 10:03:12
    Built by: p4build@re_client_43722
    Switch uptime is 14 days 10 hours 30 minutes 50 seconds
    Reboot Cause: User reboot (Intent:cause:register 78:86:50:2)
    Supervisor Card
    Processor (XLP432 Rev B1 (Secure Boot) , 1000 MHz) with 7370M bytes of memory.
    32K bytes of non-volatile configuration memory.
    7744M bytes of Supervisor Card system flash.
    #show ap essid
    ESSID Summary
    ESSID     APs  Clients  VLAN(s)                                         Encryption
    SDU_WiFi  166  189      xxxx                                             Open
    eduroam   166  36         xxxx                                             WPA 8021X AES,WPA2 8021X AES
    Num ESSID:2
    Thanks!
  • 2.  RE: Throughput problem with Aruba 7220
    Posted Apr 11, 2016 03:06 PM
    I would type "Show log system all" to see if anything is happening on the system side.
  • 3.  RE: Throughput problem with Aruba 7220
    Posted Apr 11, 2016 03:24 PM
    Thank you for the reply.
    I uploaded a piece of system log file. Could you tell me if there is something wrong in log file.
  • 4.  RE: Throughput problem with Aruba 7220
    Posted Apr 11, 2016 03:25 PM
    On second thought, do you have a screenshot from the "Performance" Tab?
  • 5.  RE: Throughput problem with Aruba 7220
    Posted Apr 11, 2016 03:31 PM
    Yes, i have ps from performance tab. But now, number of clients in 200s.
  • 6.  RE: Throughput problem with Aruba 7220
    Posted Apr 11, 2016 03:39 PM
    We probably needed that performance creenshot when you had issues.  The system log does not look like anything bad is going on from a system perspective.  I did see that you have access points that have over 40 users on them at a time.  Please PM me your email address and I will send you a link to send me your logs.tar with tech support so I can take a look.
  • 7.  RE: Throughput problem with Aruba 7220
    Posted Apr 11, 2016 03:52 PM
    Thank you for your answer cjoseph. I sent my adress. As you said, i should take performance screenshoot when problem occured. Is there anything else you want? Any log or printscreen?
  • 8.  RE: Throughput problem with Aruba 7220
    Posted Apr 11, 2016 03:56 PM
    Let me take a look at your logs.tar first, and we can take it from there.
  • 9.  RE: Throughput problem with Aruba 7220
    Posted Apr 12, 2016 05:00 AM
    Colin,
    We had just same problem again. I took print screen both "Performance" tab and "Usage" tabs. I sent you  "log.tar" file via "Secure File Downloads"
    Also i sent the printscreens here.
    Thank you.
    Hakan
  • 10.  RE: Throughput problem with Aruba 7220
    Posted Apr 12, 2016 05:44 AM
    Hakan,
    I got your logs and emailed you a few suggestions for a few crucial changes you should make.  Please let me know if you have any questions.
  • 11.  RE: Throughput problem with Aruba 7220
    Posted Apr 12, 2016 06:43 AM
    Colin,
    I received your mail. I will check your valuable suggestions.
    Thank you again for your feedback.
    Hakan Orcan
  • 12.  RE: Throughput problem with Aruba 7220
    Posted Apr 18, 2016 09:33 AM
    We solved the Throughput problem with Colin's valuable helps and analysis.
    Firstly, we reduced the RF utilization. We have too high AP power on 2.4ghz band. We set it using the following configurations:
    Configuration> Wireless> AP Configuration> click on “Kablosuz-1”. Expand RF Management, Expand 802.11g RadioClick on Adaptive Radio Management.  Click on Advanced.  ChangeAllowed Bands for 40mhz Channelstonone”.    Change the Max-TX-EIRP to 18, and change the Min-TX-Eirp to 12.  Uncheck 80 mhz support.    Click on Apply.
    We haven't Broadcast Filtering on our Virtual Aps.
    You can fix this by going to configuration:
    Wireless> AP Configuration> click on “Kablosuz-1”.  Expand Wireless LAN.  Expand Virtual AP.  Click on Kablosuz-1-vAPp.  In the right pane, make sure that Drop Broadcast and Unknown Multicast has a checkbox next to it.  Click on ApplyClick on SDU-eduroam-vAPpIn the right pane, make sure that Drop Broadcast and Unknown Multicast has a checkbox next to it.  Click on Apply.   Go to configuration> Wireless> AP Configuration> click on “SDU-Aps”.  Expand Wireless LAN.  Expand Virtual AP.  Click on SDU-WiFi-vAPpIn the right pane, make sure that Drop Broadcast and Unknown Multicast has a checkbox next to it.  Click on Apply.
    Also we have too much logging enabled on the controller. The controller generates a lot of logs.
    We use these commands to reduce log stress on our contoller.
    config t
    no logging level debugging arm
    no logging level debugging arm subcat all
    no logging level debugging arm subcat client-match
    no logging level debugging arm subcat radio-mgmt
    no logging level debugging network
    no logging level debugging network subcat all
    no logging level debugging network subcat dhcp
    no logging level debugging network subcat mobility
    no logging level debugging network subcat packet-dump
    no logging level debugging security
    no logging level debugging security subcat aaa
    no logging level debugging security subcat all
    no logging level debugging security subcat certmgr
    no logging level debugging security subcat dot1x
    no logging level debugging security subcat firewall
    no logging level debugging security subcat ids
    no logging level debugging security subcat ids-ap
    no logging level debugging security subcat ike
    no logging level debugging security subcat kerberos
    no logging level debugging security subcat mobility
    no logging level debugging security subcat ntlm
    no logging level debugging security subcat packet-trace
    no logging level debugging security subcat vpn
    no logging level debugging security subcat webserver
    no logging level debugging security subcat wl-sync
    no logging level debugging system
    no logging level debugging system subcat all
    no logging level debugging system subcat amon
    no logging level debugging system subcat amon-ale
    no logging level debugging system subcat amon-amp
    no logging level debugging system subcat ap
    no logging level debugging system subcat configuration
    no logging level debugging system subcat ha
    no logging level debugging system subcat mapc
    no logging level debugging system subcat messages
    no logging level debugging system subcat pan
    no logging level debugging system subcat reg-tbl
    no logging level debugging system subcat snmp
    no logging level debugging system subcat webserver
    no logging level debugging user
    no logging level debugging user subcat all
    no logging level debugging user subcat captive-portal
    no logging level debugging user subcat client-match
    no logging level debugging user subcat dot1x
    no logging level debugging user subcat mapc
    no logging level debugging user subcat pan
    no logging level debugging user subcat radius
    no logging level debugging user subcat voice
    no logging level debugging user subcat vpn
    no logging level debugging wireless
    no logging level debugging wireless subcat all
    logging level warning wireless
    logging level warning system
    logging level warning network
    logging level warning user
    logging level warning arm
    exit
    After entering commands, the log situations were as follows:
    (SduAruba7220) #show logging level verbose
     LOGGING LEVELS
    Facility  Level     Sub Category  Process
    arm       warnings  N/A           N/A
    network   warnings  N/A           N/A
    security  warnings  N/A           N/A
    system    warnings  N/A           N/A
    user      warnings  N/A           N/A
    wireless  warnings  N/A           N/A
    Another problem is access points have a lot of bootstrapsWe saw them using this command:
    #show ap debug counters
    According to Colin's theory, the cause of bootstraps is we use almost 200 APs and we have just one 1 gig port on controller.  According to Colin's, a single gigabit Ethernet port for every 100 access points. That is true. This is cause our users and throughput to drop randomly. We need to add secong 1 GE links to controller. And we need to have a port channel.
    Port Status
    Slot-Port  PortType  AdminState  OperState  PoE  Trusted  SpanningTree  PortMode  Speed   Duplex
    0/0/0      GE        Disabled    Down       N/A  Yes      Disabled      Access    Auto    Auto
    0/0/1      GE        Disabled    Down       N/A  Yes      Disabled      Trunk     Auto    Auto
    0/0/2      GE        Enabled     Up         N/A  Yes      Disabled      Trunk     1 Gbps  Full
    0/0/3      GE        Enabled     Down       N/A  Yes      Disabled      Access    Auto    Auto
    0/0/4      GE        Enabled     Down       N/A  Yes      Disabled      Access    Auto    Auto
    0/0/5      GE        Enabled     Down       N/A  Yes      Disabled      Access    Auto    Auto
    There is an article about to set it up.
    http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/EtherChannel-between-Aruba-and-Cisco-switch/m-p/438/highlight/true#M45
    The system works very vell. Thank you Colin Joseph.
    Best regards,
    Hakan Orcan
    Suleyman Demirel University
    Information Technologies Department
    Network and Systems Management Group
  • 13.  RE: Throughput problem with Aruba 7220
    Posted May 06, 2016 03:51 AM
    Hi!
    Thanks for letting us know what solved your problem. I do have a question regarding the "1Gbit port per 100 APs" recommendation.
    cjoseph, could you please elaborate this? I havn´t seen or heard of this recommendation in my years working with Aruba and never experienced any issues because of it. Is the recommendation based on that if the APs combined push traffic congesting that link so the AP-> Controller communication gets interupted, causing rebootstraps?
    Cheers,
  • 14.  RE: Throughput problem with Aruba 7220
    Posted Apr 12, 2016 02:44 AM
    Hi
    What about spanning-tree on the upstream switches?
    Looks like the system stops transferring data, might look like this if there is something wrong with the topology and spanning-tree re-calculates for whatever reason.
    During the recalculation and learning, the upstream device will stop switching.
    Roar
  • 15.  RE: Throughput problem with Aruba 7220
    Posted Apr 12, 2016 04:48 AM
