Total Wireless Solution
  • 1.  Total Wireless Solution
    Posted Apr 05, 2012 01:38 AM
    Hi Everyone:
         I have some custome needs,and I'm wondering whether aruba's products can achieve this effect.
         Here is the scenery.
         I have a big company.And I have many guests.Meanwhile the guests want to suffer the Internet.
         So I give them the Guest ssid,at the same time the questions are coming.
         I choose the portal authentication method,cause I also want to push some advertisements which about my company.
         After they watched the advertisements,then they are entitled to suffer the Internet.
         And I also want the custome to finish the authentication by self-register .
         Can aruba's products achieve this effect?
         Besides Controller and AP,what products should be considerd?listed names will be appreciated.
         Should I refer to the third-party product to achieve this effect? Such as portal server.
         Any help or suggestion will be appreciated.
  • 2.  RE: Total Wireless Solution
    Posted Apr 05, 2012 01:48 AM
    The Clearpass Guest solution (formerly Amigopod) can certainly do this today:  http://www.arubanetworks.com/solutions/by-application/guest-access/
  • 3.  RE: Total Wireless Solution
    Posted Apr 05, 2012 02:24 AM
    Can the clear-pass support the third-party controller to achieve the fully customize captive portal. When I do the portal authentication,is the clear-pass act as the portal server which the portals are all transported from the clear-pass,what the controller should do is only write the clear-pass server's IP address?
  • 4.  RE: Total Wireless Solution
    Posted Apr 05, 2012 02:29 AM
    Clearpass does support multiple vendors if that is what you are asking. Depending on the feature, there might be some manufacturer specific con figs that need to be done.
