[Tutorial]Calculating Number of APs for High Density Scenarios #mhc
  • 1.  [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted Mar 04, 2014 02:22 AM
    I have seem soo many times people asking regarding in how many APs they need for certain sceanrios.  And the only answers they get " it depends" but they never get a concrete asnwer...
    This tutorial will show you how to calculate the numbers of AP you need based in information you can get by calculating the Airtime Needed for those devices.
    Also to prove that the formula is working properly i took one of the Aruba success history and applied the formula!
    This Tutorial will just calculate the aproximate number of APS needed, it does not take in consideration RF issues in the auditorium deployment or other similar things
    How to calculate number of APS for High Density
    Introduction
    In this tutorial I will guide you in how and what you need to calculate the total number of APS in a High Density scenario, such as an Auditorium, Conference Room etc
    Information needed
    In order to calculate this you need to get some information of your client which is the following:
    1. Total of devices expected to be  connected
    2. Minimum BW needed for each device
    3. Type of Devices expected(Laptops, Smartphones, Tablets)
    Formula components
    MBW = Minimum BW Needed for each device
    RBW = Real BW of the Device
    ND = Number of Devices
    AP = Airtime Percentage
    Notes:
    Real BW of the Devices is the real TCP/IP Throughput which is around haft of the total raw speed
    Example 1
    A laptop with a wireless card of 3x3:3 the raw speed of it is 450Mbps
    The TCP/IP Throughput would be haft of it which is 225Mbps
    Example 2
    A smartphone with a wireless card of 1x1 the raw speed normally is = 65Mbps
    The TCP/IP Throughput would be haft of it which is 30Mbps
    Formula 1
    (MBW/RBW)*100 = AP
    Formula 2
    (AP*ND)/80 = Total of Radios
    Note:
    Remember that most of Aruba APS are dual radio which mean that each AP got 2 radios!(one 2.4ghz and the 5ghz Radio)
    Example with real Aruba Deployment
    http://technologycourses.wiki.mtnbrook.k12.al.us/file/view/Designing+WiFi+for+Multimedia+in+the+Age+of+the+iPad.pdf
    Let take this scenario and fill the information we need by reading the document above:
    Filling basic information
    1. Total of devices expected to be  connected = 100
    2. Minimum BW needed for each device = 3 Mbps(2Mbps for apps and 1Mbps for Video)
    3. Type of Devices expected(Laptops, Smartphones, Tablets) = IPADS with a maximum raw speed of 100Mbps and TCP/IP Throughput of 50Mbps(In the document implies that the IPAD provides 100Mbps Wireless speed Connection)
    Formula 1
    AP = (MBW/RBW)*100
    Let’s substitute the values
    AP = (3Mbps/50Mbps)*100
    AP = 6%
    Formula 2
    (AP*ND)/80 = Total of radios
    Total of Radios = (6*100)/80
    Total of Radios = 7.5 Radios
    Result:
    Total Amount of Aps 4( In this case 4 AP 135)
    As you see the total APS is the exact number used on the Aruba Deployment.
    Conclusion
    With this formula you will be able to calculate the approximate number of APS needed in a High Density deployment such as an auditorium.
    Remenber also that this will give you just the total of radios needed,  as in the auditoriums you sometimes or at least i do, turn off the 2.4ghz band of some of the AP because of the overlapping.  So for example 10 radios could be  7 APS,  3 of them with 2.4ghz and 5ghz on, and  4 on just 5ghz which give a total of 10 Radios.
    #AP135
  • 2.  RE: [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted Mar 04, 2014 10:10 AM
    I'd add a few more design considerations:-
    You may get away with fewer APs because...
    I'd suggest that it is worth considering the real-world utilization of any particular device or user. In your Auditorium, do you expect 100% of users to be using the bandwidth at once? If not you could consider contending the bandwith provisioning at more than 1:1
    If it's possible, can you get any usage statistics to quantify likely usage?
    You may on the other hand need more because...
    It is important to consider overhead from SSID beaconing. Although an approximation, the examples given do not account for bandwidth lost to beaconing by APs. (Good design and consideration to increasing basic rates can minimise this.)
    You probably don't want to re-use any 2.4 channels. Even given a highly engineered design with respect to APs, the client broadcasts are going to be omni-directional.
    The approximation assumes that all cients will associate at top rate. In reality a good proportion will rate shift down and send data at lower rates. Aruba's ClientMatch can help  to some extent with this by shifting clients to the most suitable AP.
  • 3.  RE: [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted Mar 04, 2014 10:20 AM
    Hello !
    Thanks for you reply
    remenber that in the beggining i said this is just to calculate a aproximate number of APS that you need, which will help you to have an idea around how many aps you need in there
    Answering you
    Yes this takes
    "'d suggest that it is worth considering the real-world utilization of any particular device or user. In your Auditorium, do you expect 100% of users to be using the bandwidth at once? If not you could consider contending the bandwith provisioning at more than 1:1"
    Yes it takes in mind that they are all using the minimum BW and im agree with you that this will hardly happen but  it considers the worts case scenario.
    "You probably don't want to re-use any 2.4 channels. Even given a highly engineered design with respect to APs, the client broadcasts are going to be omni-directional"
    I already made a point of this on the conclusions
    I have been using this for a a time and it is working pretty good, i mean for a starting point it is.   But its true there are other things you need to take in consideration but for a starting point it does helps a lot.  Like i said in the begginng this does not take in consideration thigns like RF issues or other things. :)
    Cheers
    Carlos
  • 4.  RE: [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted Mar 04, 2014 10:29 AM
    Ha yes, sorry I should have begun by saying that I agree your post was a good starting point.
  • 5.  RE: [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted Mar 04, 2014 10:32 AM
    Dont worry everything is cool!
    I always apreciate  good comments
    Cheers
    Carlos
  • 6.  RE: [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted Mar 17, 2014 01:36 PM
    Thanks you all for the kudos!
    Lets keep them coming :)
    Cheers
    Carlos
  • 7.  RE: [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted May 31, 2014 04:02 AM
    Formula 1
    (MBW/RBW)*100 = AP
    Formula 2
    I m not really understand on the formula. Why is that /80 ?
    Could you please explain more on how the formula work?
    Thanks in advance.
  • 8.  RE: [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted Jun 01, 2014 01:17 AM
    the 80 is a 80% of airtime utilization
    Im dividing it with 80% becasue is a more realistic number.
    In the real world a single channel would be maxed out at 80% of channel utilization not really on 100% so thats why that number
    With the first formula you are calculating the Aritime percentage using the minimum BW needed for each device and the real max BW of the device(depending in what you using for example a tablet normally does not go over 65mbs... but a 2x2:2 on 5ghz can go up to 300Mbs)
    With the second formula you calculate the total radios needed when i say radio i mean:  for an AP 105 for example it has a radio of 2.4ghz and 5ghz working at the same time so that would be one AP but 2 radios...
    Now the second formula  to do that use the airtime porcentage and dividing it with the number of the devices... Remenber all those devices are sharing the same media...
    does this asnwer your question??? im not that great explaining :/
  • 9.  RE: [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted Jun 02, 2014 05:12 AM
    definitely thanks!!!
  • 10.  RE: [Tutorial]Calculating Number of APs for High Density Scenarios #mhc
    Posted May 03, 2018 06:40 AM
    Hi
    I have question about formula as  below.
    AP = (MBW/RBW)*100 ( what is 100 ? )
    AP = 6% ( how to calculate to   6%   )
    and
    Why , you using ap 135 ?
    Yongyuth
